It is currently Sat Aug 18, 2018 9:33 pm
PostPosted: Fri Jun 02, 2017 11:04 pm
Hi
In the next few weeks I'll be sorting out a dark blue focus rs and a sky blue M5 both with medium imperfections and swirls. I'm currently using s17+ on helix pads, but I'm in need of a top up. Do you think I should carry on with the s17 or change to Menzerna polish and pads ?
PostPosted: Sat Jun 03, 2017 9:33 am
I'm not sure why you what to do that? Are you having issues with the Scholl polish.
All I can tell you is, if you are using a DA to apposed a rotary with Menzerna polishes it will take a lot longer to break the polish down! I use a rotary and I don't like Menzerna polishes just for that reason. Lazy I guess :lol:
PostPosted: Sat Jun 03, 2017 9:42 am
S17+ isn't really a 'medium' imperfections and swirls polish...especially in hotter weather when more lubrication is needed to prevent 'clumping' on the pad..
S30+ has far higher lubrication levels and is more appropriate for the imperfections you describe and should be fine on a hexlogic pad and a DA.
PostPosted: Sat Jun 03, 2017 10:23 am
Thanks for the replies. S17 is fine just didn't know if the Menzerna polish would be better for harder paints. S30 sounds good might give that a try.
Any other suggestions for polish using a da ?
PostPosted: Mon Jun 05, 2017 1:43 pm
Have a look at the Meguiars DA Microfiber Correction System
