It is currently Mon Aug 20, 2018 1:27 pm
 Post subject: Volvo 2015 paint
PostPosted: Sun Feb 14, 2016 3:04 pm
Hi
Changed my car to a Volvo (2015)
I have some menzerna pads from my last car (VW) and Menzerna polish ...
Just thinking about replacing them and getting some new polish ... what would you go with ?
It just needs a polish to remove the normal marks.
Would you use what I have and take it from there or some new pads and compounds
Would Meguiars DA Microfiber Correction Compound and pads be a good match or
SONAX - EX 04-06 Polish and pads ?
Richard
 Post subject: Re: Volvo 2015 paint
PostPosted: Sun Feb 14, 2016 4:13 pm
I'd stick with the pads you have and simply get some Scholl S17+ polish to use with them.
If you're not happy with the pads then change those at a later date; probably for some CG Hex's
PostPosted: Sun May 08, 2016 5:21 pm
Hi ya, I did a 2014 Volvo C70 convertible I'm dark silver colour last week. The paint is hard as hell :lol: I found that menzerna medium cut 2500 and an orange hex logic pad cut through the imperfections quite nicely. I just made sure to spread the polish on speed 1 using my DAS 6 pro plus then misted the pad once with water and carried on polishing on speed 5.
Then I refined the finish using Menzerna super finish 3800 on a white hex logic using the same system as above, then glazed using Prima Amigo and waxed with Collinite 845. Came out lovely.
Hope this helps mate :)
