First go with Gtechniq P1/C2
For any other detailing chat please feel free to post here.
GIZTO29
Post by GIZTO29 » Sun Aug 15, 2010 10:37 pm
I still havnt used mine either :oops:
freon warrior
Post by freon warrior » Sun Aug 15, 2010 10:45 pm
pjgh wrote:I don't mind at all ... in fact, I've yet to have a "proper go" with P1 and C2 :oops: so your account is most welcome.
Did you use C2 neat? That's my plan ... and then use C2 diluted to maintain after each wash.
Yes it was neat Paul, easy on and off. I have made up a 1/2 litre of QD too.
Post by Ash » Sun Aug 15, 2010 10:46 pm
Paul (freon warrior) as you said it really does dust but I think it worth putting up with it for the great results :wink:
The water spray really does help keep the dust down.
pjgh
Contact:
Post by pjgh » Sun Aug 15, 2010 10:48 pm
... so if dust does fly out, mist some water over the surface and just go over to pick up the polish dust again?
freon warrior
Post by freon warrior » Sun Aug 15, 2010 10:53 pm
The dust seemed to get everywhere, down the wings, rad grille and in the badge too! The spritz helped to work the polish longer but the dried 'fling' was a bit of a pain.
Post by Ash » Sun Aug 15, 2010 10:59 pm
I think the trick is to keep the pad moist because the polish is water based.
freon warrior
Post by freon warrior » Sun Aug 15, 2010 11:05 pm
I will persevere because inn the end the finished article should be great, hopefully.
Post by Ash » Mon Aug 16, 2010 9:02 am
freon warrior wrote:I will persevere because inn the end the finished article should be great, hopefully.
May be of help http://www.detailingworld.co.uk/forum/s ... p?t=162533
It may be worth asking Rob at Gtechniq for tips :idea: .
I had a similar problem with Megs Swirl X and I got round it by adding a very small blob of Britemax polishing glaze on the pad. I guess it just added some extra lube. But I haven't tried it with the P1
This looks good http://www.detailingworld.co.uk/forum/s ... p?t=179044
freon warrior
Post by freon warrior » Mon Aug 16, 2010 4:23 pm
Thanks Ash, I had seen the Porky thread but not the other one. As I say with a bit more use I should get the hang of it.
Here is a slightly better pic.
Last edited by freon warrior on Mon Aug 16, 2010 10:04 pm, edited 1 time in total.
Post by Ash » Mon Aug 16, 2010 5:20 pm
Looks great pal :cool:
paulmc08
Post by paulmc08 » Mon Aug 16, 2010 9:02 pm
yep iron cut does look a brilliant product,it's just a pity i didnt buy some as i started a black Range Rover Sport today,after going to look at it on Sat,now the vehicle had not seen polish or tar remover from new,.After the degrease,wash,tar removel and claying stage's and a couple more washe's for good luck :lol: i seen the severity of the iron filing's all over the vehicle from head to toe(HOLY JAFFA CAKE'S BATMAN) so back in for round two of claying :mad: where as IronCut would have quickly and easily solved the problem,and what have i learned,well if you like the look of a product and it will reduce the prep stage then get it.So off to order a million litre's,ok then maybe a gallon :lol:
Post by Ash » Mon Aug 16, 2010 9:07 pm
paulmc08 wrote:yep iron cut does look a brilliant product,it's just a pity i didnt buy some as i started a black Range Rover Sport today,after going to look at it on Sat,now the vehicle had not seen polish or tar remover from new,.After the degrease,wash,tar removel and claying stage's and a couple more washe's for good luck :lol: i seen the severity of the iron filing's all over the vehicle from head to toe(HOLY JAFFA CAKE'S BATMAN) so back in for round two of claying :mad: where as IronCut would have quickly and easily solved the problem,and what have i learned,well if you like the look of a product and it will reduce the prep stage then get it.So off to order a million litre's,ok then maybe a gallon :lol:
:? This thread is about Gtechniq products not Iron Cut. :wink:
freon warrior
Post by freon warrior » Mon Aug 16, 2010 10:17 pm
Ash wrote:Looks great pal :cool:
Thanks Ash, it has not fully corrected, so another go would probably sort it, but I plan on leaving it on a durability test.
Post by Ash » Tue Aug 17, 2010 6:21 pm
:cool:. I believe the C2 has a 6 month life but I'm not sure if that includes topping up with the QD. I don't think I could wait that long without applying something :lol:
RussST
Post by RussST » Thu Nov 04, 2010 11:19 pm
Untitled by RussZS, on Flickr
I'm a bit late to the party with G|T, but I'm looking forward to trying it
I hope I can 'master' P1, so that I can use that then C2 on most of my details, which should cut down time, yet yield impressive results.
Any further thoughts on using P1 by rotary?
Post Reply
