It is currently Thu Sep 20, 2018 12:20 am
 Post subject: Tar remover spray bottle
PostPosted: Mon Jan 30, 2017 2:34 pm
Hello all,
I live on an estate-in-progress where the builders always seems to be digging up freshly tarred roads and then covering them over again. So I end up with a lot of tar on the alloys and body panels. I have been using Tardis and ObilTARate, both of which do the job. Spray an area, allow it to dwell, agitate if necessary and wipe clean. Repeat.
But after a few weeks, the spray bottles all start to fail. No doubt the solvents in the products attack the plastics and rubber in the spray heads. So I end up with more product running down the bottle, and dissolving the driveway, than I do on the car. I have tried removing the spray heads and rinsing them with a soap solution and flushing with water, which does make them last a little longer.
Any suggestions for a spray bottle that can handle these sort of solvents long term?
PostPosted: Mon Jan 30, 2017 2:48 pm
I used Raceglaze's Tar remover...it comes in an aluminium bottle as it's so powerful. However, the spray nozzle disolves!
So I turned to the CYC Chemical resitant sprayer and attached it onto my aluminum bottle.....no issues in over a year :)
http://www.cleanyourcar.co.uk/index.php?_a=viewProd&productId=373
PostPosted: Mon Jan 30, 2017 3:09 pm
Thanks Willington, I don't know why I didn't look at Raceglaze's products. I'll give both of them a try.
And I have also tried Kenotek Ultra, on your recommendation. Very nice and works even in the cold. My 1 year old white car went a lovely shade of pink.
PostPosted: Mon Jan 30, 2017 7:56 pm
When you order the Tar remover, tell them on the phone about your concerns for chemical resistance of the spray nozzle...they may be able to switch it for a specialist one for you.
I'm glad that you liked the Kenotech Ultra. Perhaps you could add to my Product Test post about your experience using it?
PostPosted: Tue Jan 31, 2017 12:14 pm
With pleasure.
