It is currently Tue Apr 24, 2018 4:05 am
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
PostPosted: Tue Mar 20, 2007 12:14 am
In this thread I aim to present some general guidance tips for people who have recently bought a Porter Cable 7424 and describe the machine a little! :)
The Porter Cable 7424
Browsing this forum, you cannot help but notice that the PC7424 is extremely popular. It is a dual-action polisher that is safe to use and can remove paint defects to help you achieve that sought after swirl free finish. Its a popular tool owing to hte dual-action nature which makes it very safe to use, much safer than a rotary in the hands of a novice. Yet swirl removal is still possible with it, so you come close to getting the best of both worlds! :)
The tool in all its glory:
What Is A "Dual-Action" Polisher
Dual-action describes the way that the pad moves with the polisher, and the dual-action nature is what makes the Porter Cable 7424 (and 7335) a speical tool. Shown in the diagram is the difference between a conventional rotary polisher and a dual-action polisher:
The conventional rotary pad spins on a single axis, forming a circular orbit of constant radius. This nature makes the rotary quite an agressive tool with the ability to cut paint quickly - while this makes it more effective at swirl removal, it also makes paint damage a real possibility in the hands of a novice.
The dual-action pad not only spins, but it oscillates as well developping random orbits, with varying elliptical orbits. This makes the cutting action much less aggressive and much safer for novices to use. The motion very closely mimicks hand polishing, only the 7424 can oscillate up to 6000 times a minute, which is completely impossible by hand!! :) This fast oscillation generates much more heat than by hand to more effectively break products down and cut into the paint.
So Many Polishes - Which to Choose??
Once you have you're PC, you are confronted with a daunting array of polishes from a wide variety of manufacturers. At the end of the day, all of these products can be summed up into groups that carry out certain tasks:
Compounds
These are the most aggressive cutting polishes and are generally applied by rotary polisher to deal with severe swirl marks and scratches. You can use a compound on a PC but it requires a 4" pad to generate enough heat to effectively break the product down. Examples of compound: Menzerna Power Gloss Compound, Poorboys SSR3. Only choose a compound if your paint has very severe swirl marks and the cutting polish is proving unsuccessful in dealing with them.
Cutting Polishes
These are medium abbrassive polishes that are designed for the removal of medium swirl marks in paint. They can be applied on a 6" pad, or for extra cutting ability, a 4" pad. Only choose a cutting polish if the swirls in your paint are too severe to be removed by a light cutting polish. Examples of cutting polishes are: Menzerna Intensive Polish, Poorboys SSR2.5, Meguiars #83.
Light Cutting Polish / Finishing Polish
These are light abbrassive polishes that are designed for finishing - ie use after a more aggressive polish or compound to remove any marring that may have been left by the more aggressive product and to restore surface gloss. The can be applied on a 6" pad. Examples of light cutting polishes are: Poorboys SSR1, Meguiars #80.
Glazes
These are essentially moisturisers for paint! They add paint oils to replace depleted oil and to wetten the shine and deepen the colour and are a highly recommended part of the detailing process. Examples of glazes are: Menzerna Finishing Touch Glaze, Meguiars #7.
What Pads to Choose??
There are four main classes of pads available from manufacturers and these are colour coded so you know which pad is which. Alas, different manufacturers use different colour codes! The texture of the foam effects what the pad does - ie how much it cuts etc. Summarised in the table below is a breif guide to the uses of the classes of pad:
If you are using Lake Country pads, the colour coding is as follows:
Yellow = Cutting; Orange = Light Cutting; White = Polishing; Black = Finishing.
If you are using Sonus DAS pads, the colour coding is as follows:
Orange = Cutting; Green = Light Cutting; Blue = Polishing/Finishing
If you are using Sonus SFX pads, the colour coding is as follows:
Yellow = Cutting; White = Light Cutting; Blue = Polishing/Finishing
If you are using Meguiars pads the colour coding is as follows:
Burgandy = Cutting; Yellow = Light Cutting/Polishing; Beige = Finishing
Note that the above table is intended as a starters guidance only, and over time you will find out which pad and product combinations that you like best!
Setting Up The PC7424 For Use
Getting ready to use the Porter Cable... If you turn the Porter Cable upside down, you will see the following:
Make sure that if you are planning to use 4" pads that you have the counter-weight for 5" pads fitted. Some pCs are now being supplied with a 6" counter-weight which will make the machine very hard to control with a 4" pad fitted. 5" counter-weights are available from [url="http://www.polishedbliss.co.uk"]http://www.polishedbliss.co.uk[/url] if required.
First off, choose the correct backing plate for the pad you intend to use - 3.5" backing plate for a 4" pad, 5" or 6" backing plate for a 6" pad:
First off, fit the backing plate to the Porter Cable. Using the flat spanner supplied with the machine, hold the centre nut as shown:
Now, screw the plate into the thread in the middle of this centre nut while holding the nut still with the spanner to prevent it from spinning with the pad, and tighten the backing plate continuing to hold the centre nut with the spanner:
The pads fit to the backing plate using a velcro (sometimes called "hook & loop") system so just stick the pad securely to the backing plate, trying to keep the plate in the centre of the pad area.
Once the pad is fitted, you just need to plug the PC in and you're ready - make sure you use a transformer however!! Plug the transformer into the mains (230V) and plug the Porter Cable into the 110V output of the transformer:
Never plug the PC straight into the mains, this will damage it irreperably!
Polishing with the PC7424
The key to successful polishing with the PC is to work on small areas, and take your time. What follows is a generic guide to polishing with the PC, as you work with the machine you will develop the technique that you feel most comfortable with, this is aimed at being a starting guide.
To hold the PC, I like the place my right hand over the head of the PC and have my left hand at the back of the PC:
This allows me to put pressure over the polishing pad while the PC is in use, and pressure is required to get decent swirl removal (but not too much, see later!)
First off, apply the polish to the pad on the PC, in either an X (which stops three quarters of the way out from the centre) or a circle round the edge of the pad, about quarter of the way in from the edge.
Next, with the machine switched off, smear this across a small area of about 2' x 2'. Make sure you can comfortably reach the hole area and that you are not stretching too far - the more comfortably you can reach areas the happier you'll be operating the tool. A small ladder is useful for doing the roof, especially if you're short! After spreading the polish, turn the machine on at about speed 3.
Do a single fast pass with light pressure over the pad to further spread the polish out.
Then turn the machine up to speed 5, and make a single slow pass with pressure applied over the pad. Move the PC at around 2cm per second in either a fore and aft motion or a figure of eight motion, what ever you are most comfortable with providing you achieve even coverage. (I prefer a fore and aft motion).
Next turn the machine up to full speed - speed 6 and make several slow passes with pressure applied over the pad until the polish begins to dust. At this point, switch off the machine and buff the residue away with a microfibre towel. If the residue resists easy buffing, a little spray of Quick Detailer spray on the mf towel should help remove the residue more easily.
How much pressure?? - apply about 10 - 15lbs of pressure. To get an idea of what this feels like, you can get out the bathroom scales and puch down till it reads 10 - 15lbs plus the weight of the PC. Or, I much prefer the following: push down on the PC until you get a noticebale change in pitch from the machine and the pad stops visibly spinning, it is just oscillating. Then reduce the pressure ever so slightly so that the pad begins to spin again, and this amount of pressure is good.
Glazing with the PC7424
The PC can be used for other tasks than polishing. Glazing really benefits from using the PC as the extra speed of the PC over hand application works the oils in glazes nicely into the paint. I find the following process works well for applying glazes:
Apply product to pad (as above for polishing, X or circle) and smear over a small area. Turn machine on at speed 3 and make one fast pass to spread the product more and then one slower pass to begin working the glaze into the paint. Then turn the machine up to speed 5 for two or three more slow passes. All with light pressure over the pad. Then buff off residue with an mf towel.
Applying Liquid Waxes & Sealents by PC7424
The PC can cut down the time taken and effort required in applying liquid waxes and sealents! Again, apply the product to the pad as the glazing or polishing stage above. Turn then machine onto speed 2 or 3 and move the PC slowly across the paintwork to spread the product evenly. Fast speeds are not required for this process. Always observe the manufacturers recommendarions for the time left for the product to cure before buffing off residue.
Applying Paste Waxes by PC7424
Even some paste waxes can be applied by the PC, though, many people prefer to apply these by hand. If you wish to apply by PC, follow the process for liquid waxes and sealents above. Most pastes waxes can be popped out of their containers, just rub the wax round the PC pad to charge the pads up, a but like buttering a piece of toast! Again observe the manufacturers guidelines for the length of time the product should be left to cure.
And there we have it! If you've just bought a PC, I hope you find this guide helpful in getting started. You will develop your own methods with experience (for example the speeds you like, the pad and polish combos you like) which may differ from those here, what ever works for you, go for it! I hope you enjoy the tool that I consider to be one of the best detailing purchases I ever made! :)
PostPosted: Tue Mar 20, 2007 12:22 am
Fantastic guide this Dave. Thanks ever so much for sharing, as with all of them.
PostPosted: Tue Mar 20, 2007 8:04 pm
Excellent guide Dave. I think it was reading your guide originally that made me get a pc!
PostPosted: Wed Mar 21, 2007 12:37 am
This realy is a thing i need but unfortunatly i dont have that sorta money :(
PostPosted: Sat Mar 24, 2007 9:42 pm
Excellent guide Dave, I am seriously thinking about getting one of these. Is there a UK model?
2009 (MY10 59 Plate) Audi TT Coupe 2.0TFSI Ibis White, RS4's, Adaptive Xenons, MFSW, Parking Sensors, LED Interior Light Pack, Chrome Tips, Phantom Black Grille and Auto Light/Rain/Mirror Pack.
PostPosted: Sun Mar 25, 2007 1:16 am
No as yet there is no UK model. Meguiars have one in the pipeline, but last timne I spoke to them they mentioned August and a £200 price tag. So it still may work out cheaper importing one :( I think if Meguiars get the pricing right they will clean up.
PostPosted: Sun Mar 25, 2007 1:32 am
I think you are right Tim. Would it still be cheaper even when you include the transformer etc?
PostPosted: Sun Mar 25, 2007 9:22 am
I believe Meguiars are currently having some issues patent wise with this UK model, and the date of release has gone back from April to an unknown date which is a pity... At £200 also, thats quite stepp unless they are including in that an excellent package of pads and polishes, but just for the machine and a small set of pads, £200 will buy you more from Autopia...
PostPosted: Tue Apr 10, 2007 1:42 pm
Dave great guide. I've been directed here from Totaltorque.net.
I've had a PC for about 2 years and am continually frustrated at how ineffectual it is at making any inroads into the paint on my A3.
I've used PB SSR 2.5 and Meguairs #83 with a 4" cutting pad but couldnt make inroads into light scratches on the bonnet. I could possibly go to SSR 3 etc but I'm aware that I could go too far!
What is your experience of VAG paint and what can be achieved without resorting to Rotary?
PostPosted: Tue Apr 10, 2007 2:02 pm
Dave ignore the post - just noticed one further down on the exact topic! :oops:
I may have to get some practical help on how to get the best out of my 7242 at some point so as I'm a Dundee lad I may have to look you up with a pile of cleaning material - thats unless of course you are wary of complete strangers turning up at your door :D
PostPosted: Tue Apr 10, 2007 3:11 pm
Drop me a PM mate, and I'll pop over and pay you a visit for getting the best out of the PC.
PostPosted: Tue Apr 10, 2007 3:39 pm
Dave - PM sent - :D
PostPosted: Tue Apr 10, 2007 3:47 pm
cheechy wrote:
Dave - PM sent - :D
Got it cheers. :D
PostPosted: Sun Jun 14, 2009 7:28 pm
Top line I take it this all goes for the G220 as well :cool:
BMW 120d se red
Honda CR-V EX Pearl grey
Quality isn't cheap but lasts longer
http://www.facebook.com/FaringdonAutoDetailing
Users browsing this forum: No registered users and 0 guests
