It is currently Sun Jun 24, 2018 9:51 am
PostPosted: Tue Sep 12, 2017 7:05 pm
Hi guys, after for some advice pleased.
After picking up my new car thought would spend the weekend giving it a good clean. Started out with the usual clean, clay bar, clean, dodo juice lime prime lite then meguires ultimate wax. The wax was fine for my previous car but for some reason really not come out right on the new car. Although put a thin layer on it was an absolute nightmare to come off. I had left it to haze as normal but really has not worked with this car and really disappointed with the result.
I'm going to switch back to dodo juice wax, but wondering is there a good product to use to get rid of the old wax? Been reading about dodo juice need for speed or the Angelwax stripped ease wax remover? Would you recommend these or something else? Can I just use the DJ lime prime lite again??
Thanks!
PostPosted: Tue Sep 12, 2017 9:34 pm
Try an APC, FL is also a good, cheaper option for stripping wax/sealant layers...
PostPosted: Wed Sep 13, 2017 1:24 pm
Use a high dilution of car shampoo (3 or 4 times greater than normal) when you next wash, use the Lime Prime Lite (it's a cleanser) and re-wax with Dodo Juice.
PostPosted: Wed Sep 13, 2017 8:33 pm
Thanks, I actually use DJ born to be mild shampoo, will that still work at a higher concentration??
PostPosted: Thu Sep 14, 2017 1:27 pm
It should
