It is currently Tue Feb 20, 2018 4:29 pm
 Post subject: Plastic peeling?
PostPosted: Sat May 14, 2016 10:35 am
Long time no posting, really been struggling to find an answer to this!?
Picked up a new car and the plastic on one the wing mirrors just won't shine in patches! Doesn't mater what I use it just stays dull, unlike the rest.
Are there any products that may work or am I into the replacement zone?
 Post subject: Re: Plastic peeling?
PostPosted: Sat May 14, 2016 11:25 am
There is a product called RubberDub (DodoJuice version is called Tyromania) that is similar to a shoe polish. Build up a couple of layers of it and give it a buff up with a shoe brush. No guarantees that it will work, however I can verify that it works on dull plastics and rubber alike...long lasting also.
Alternatively, you could try a plastic dye to return colour conformity and then apply a glossy sealant over the top.
If you could post a piccy of the offending plastic area....others may have other solutions.
PostPosted: Sat May 14, 2016 11:46 am
Thanks, I'll check them out.
I tried posting a bit but it says the board limit has been reached?
PostPosted: Sat May 14, 2016 11:54 am
You have to post photos via something like photobucket or Flickr. The forum unload system does not work.
viewtopic.php?f=20&t=6977
You could also look at Gtechniq - C4 Permanent Trim Restorer
