It is currently Tue Feb 20, 2018 4:20 pm
Post new topic Reply to topic  [ 2 posts ]
 Post subject: snow foam lance.
PostPosted: Wed Mar 02, 2016 10:34 am
Hi all,
i have a karcher k2 pressure washer with a karcher foam lance, its only the cheap 0.3L one, what lance would give better results without costing a fortune as its only for personal use. Or is more about the machine pressure?
 Post subject: Re: snow foam lance.
PostPosted: Wed Mar 02, 2016 1:20 pm
The CYC foam lance will provide you with a 'quality' dispersal of foam as it is fully adjustable. It's not that more expensive than the Karcher larger foam attachment.
However, the lance is only one part of the equation....the pressure of the water at your home, the length of hose used, the hardness/softness of the water and the pressure washer itself.
Water pressure regulations state that it must be at a minimum of 1Bar....enough to create a fountain of water upwards of 30 feet. So the length of the supply hose, if water pressure is 1 Bar, should be 30 feet long. Increase the length of the hose, at this pressure, and the washer itself can't do it's job fully.
